Changing voice
kitsunzoro
Changing voice
Post by kitsunzoro » Mon Apr 19, 2021 1:59 pm
Is it possible to change your voice to another voice or change a voice in a good way?
Re: Changing voice
Post by kozikowski » Mon Apr 19, 2021 2:13 pm
As a fuzzy rule, no. The problem isn't changing the pitch, it's that all the parts of your voice don't change. I use the silly example of a large man and my kid sister whispering at you. You would not necessarily be able to tell who was who, but the instant they actually talked, it would be obvious who was speaking. So the software would have to be able to manage that.
There are packages which can do a reasonable job voice changing, but not from Audacity.
"Make me sound like an announcer" is a common request.
There is an addition problem of theater. You may sound like a large male announcer, but you still use the same words in the same way as my Aunt Tilly, the original voice.
Trebor
Re: Changing voice
Post by Trebor » Mon Apr 19, 2021 5:57 pm
Kerovee plugin is free & works in Audcaity on Windows.
but it is old & croaky/computery ...
process-server, before-after Kerovee.flac
(206.55 KiB) Downloaded 6 times
Re: Changing voice
Post by kozikowski » Mon Apr 19, 2021 6:44 pm
And here's another one.
https://www.youtube.com/watch?v=ztNBCEq8rxQ&t=150s
He's doing cartoon voices, but the real human voices he did are pretty good.
