*NO* version of Audacity works for me in Windows 10
Ivalogic
Re: *NO* version of Audacity works for me in Windows 10
Post by Ivalogic » Wed Apr 21, 2021 7:57 pm
BrianGygi wrote:
Wed Apr 21, 2021 2:37 pm
and right-clicking on the Audacity app.
As deed, to edit the permissions of a folder, you should right click on the folder, or get in the folder and right click on the background, no an app inside it.
Also, changing the permissions to the executable of the program, wont change the permissions that executable perceives from other folders.
