I followed the directions in the manual tried vst (dll) and vst3 separately
only one in plug-ins at a time
They appear I choose enable click ok get error message
Any ideas?
Audacity 3
Thanks
Installing VST Span Voxengo
Terry Cano
- Operating System: Windows 7
Re: Installing VST Span Voxengo
There are different versions: you need the 32-bit VST version for Audacity in Windows, (& not 64-bit, nor VST3).Terry Cano wrote: ↑Sat Apr 17, 2021 12:28 amI followed the directions in the manual tried vst (dll) and vst3 separately
Any ideas?,
