Hi,
Im a new user so installed the latest version last night (V3.0.0), im on Windows 10 Pro 20H2 build 19042.867.
When I used the built in screenshot feature last night it worked as expected, only saved the section the button pressed related to. Today I tried to use it but it captures the screen used to select which screenshot to save.
I did a search and found a few posts but they was for an older version, the posts contained no fixes for the issue.
The PC was put into sleep mode last night when i finished using it and it was the first thing i went to when i woke it. Absolutely no changes was made in between, i restarted the PC and uninstalled, restarted again then installed but problem persists.
I know I could use normal screenshot and cut or use the snipping tool but both are slower for me, plus I get bugged by not being able to work out why its broken.
Thanks
