Error message when importing mp3-file
юра00
Post by юра00 » Thu Apr 15, 2021 1:17 pm
After trying import mp3-file
https://mega.dp.ua/ru/RL4Czy
The error message appears:
The file is just like any other, I played it with Windows Media Player easily.
Please, find the reason and correct! Audacity version 3.0.2
Re: Error message when importing mp3-file
Post by steve » Thu Apr 15, 2021 1:45 pm
The current version of Audacity is 3.0.0 https://www.audacityteam.org/download/windows/
That MP3 file works fine for me with Audacity 3.0.0.
юра00
Post by юра00 » Thu Apr 15, 2021 2:00 pm
How does importing of this file behave itself in the version 3.0.2? I mean, there’s never been a mistake like that before.
Post by steve » Thu Apr 15, 2021 2:23 pm
The latest release version of Audacity is 3.0.0.
Are you using "Audacity 3.0.2 alpha", or "Audacity 3.0.2 rc02"?
Where did you get that version of Audacity from?
Note that pre-release versions of Audacity should not be used for production work. Any pre-release versions of Audacity that are made available through official channels are for testing purposes only.
We are not able to provide user support for any versions of Audacity that are obtained through unofficial channels as we have no way of knowing if they have been modified or infected with malware.
юра00
Post by юра00 » Thu Apr 15, 2021 3:06 pm
I'm using Audacity 3.0.2 rc02
I got it from the source:
https://www.fosshub.com/Audacity-devel.html
It was adviced by one of your specialists. I’ll tell you more. This unreadable file is not the only one!
Post by steve » Thu Apr 15, 2021 3:57 pm
Thanks for the info.
That MP3 works fine for me with Audacity 3.0.2 rc2
First Track000.png (33.86 KiB) Viewed 336 times
юра00
Post by юра00 » Thu Apr 15, 2021 5:35 pm
I'd sure like to know, why I can’t import. I downloaded the same file from the other site (vk.com) - error message again! Why won't the program let it in?
https://mega.dp.ua/ru/wfNKLRz
jademan
Forum Crew
Post by jademan » Fri Apr 16, 2021 10:11 pm
I would like to know why as well. I tried it in 2.4.2, in 3.0.0, and in 3.0.2 RC02 with no issues - I am unable to duplicate the problem. Have you tried resetting your preferences: Tools > Reset Configuration or rebooting.
Since you shouldn't be running production on 3.0.2, try it in 3.0.0 or 2.4.2. If you still have problems, try importing it with FFmpeg. see here: viewtopic.php?p=408815#p408815
If that doesn't fix it, try converting it to .AIF in VLC, and importing the .AIF into Audacity.
I hope this helps. :D
motorcongtudongpth
Post by motorcongtudongpth » Sat Apr 17, 2021 2:10 am
I would like to know why as well. I tried it in 2.4.2, in 3.0.0, and in 3.0.2 RC02 with no issues - I am unable to duplicate the problem. Have you tried resetting your preferences: Tools > Reset Configuration or rebooting. Readmore
юра00
Post by юра00 » Sat Apr 17, 2021 7:30 am
Hi! I converted it with online converter. From mp3 to mp3, without changing, formally. Then, everything is fine. There is still a question about the original, nonconverted file. Audacity for some reason doesn't recognize it's format, as mp3. Though it's really mp3. I tried importing it with mp3DirectCut - everything is fine!
