new computer
Craig Buhler
new computer
Post by Craig Buhler » Thu Apr 15, 2021 9:02 am
I just upgraded to a new, faster computer (from Windows 7 to Windows 10).
When i press record, it always used to create a new track and begin at the cursor.
Now, it is appending the recording to the end of an existing track.
Also, when i press record, the other tracks do NOT play.
waxcylinder
Re: new computer
Post by waxcylinder » Thu Apr 15, 2021 9:23 am
And you upgraded to a newer version of Audacity I'm guessing.
We swapped it around so that
a) unmodified Record - records on the same track
b) Shift+Record - records on a new track.
It used to be the other way around - if you want to revert to the old way just go to Recording Preferences and check "on" Record on a new track, which is "off" by default.
See: https://manual.audacityteam.org/man/rec ... ences.html
Also there check "on" Play other tracks while recording (overdub)
Peter.
Craig Buhler
Re: new computer
Post by Craig Buhler » Mon Apr 19, 2021 5:22 am
Thank you so very much, Peter. That's what i needed. That fixed the "RECORD" button.
And the "R" keyboard shortcut can be reset in EDIT / PREFERENCES / KEYBOARD.
Is there a way i can auto-receive an email, when my question is answered? Your response did not generate an autoemail. I only noticed it when returning to the Forum. OK, I see, check the box at the bottom which says, "NOTIFY ME WHEN A REPLY IS POSTED."
