For some reason, I can’t get my audio to export as mp3
I record the audio from a show on Youtube and after it finishes, I stop it and click export as mp3. It shows the destination, it has the file name and save as mp3 files. I click the save and the next box coming up says edit tags and when I save that, nothing happens. What box should come up next after the first one and start the export. Sorry if I’m not explaining it clear enough. Thanks for your help.
That just saves the metadata template. Usually that’s not necessary.
Click OK in the metadata editing box and the MP3 file should be created/saved.
Thanks for your reply, unfortunately that doesn’t work. From what I’ve read, it suppose to go through thd downloading process but it doesn’t happen. After I save it as a mp3, is the metadata template supposed to come up? No matter what I click on, it won’t export. Thanks.
The tag/metadata dialog shows-up BEFORE the file is created/saved because the metadata is embedded in the MP3.
But there is a checkbox in at the bottom of the metadata dialog that says. “Don’t show this when exporting audio”. I don’t know if that will help…
Thank you for your help.
