Change Tempo Effect Crashes
waxcylinder
Re: Change Tempo Effect Crashes
Post by waxcylinder » Sat Apr 24, 2021 3:46 pm
Brian Smith wrote:
Sat Apr 24, 2021 3:41 pm
If it helps, the progress bar moves to within a whisker of the end, then Audacity 'thinks' for a second or two before disappearing from the screen. No error message is displayed.
That's what happens for me - but only when I have part of the selection in negative time :?
Peter.
Brian Smith
Post by Brian Smith » Sun May 30, 2021 1:38 pm
This is still an issue for me, occurring randomly when applied to some clips but not others. None of the clips or projects are in negative time. Is there any information I can gather that might help identify the cause?
jademan
Forum Crew
Post by jademan » Mon May 31, 2021 11:18 am
So a fix for your issue has been applied to the current alpha 3.0.3. You may take a sneak peak at it here to see if it corrects your problem: https://github.com/audacity/audacity/ac ... /875209724 - For Windows, you will want to download the item: Windows_32bit_9f59879
Note that alpha builds are available for testing purposes only. They likely contain errors/bugs, they are not supported, and should NEVER be used for production work.
Brian Smith
Post by Brian Smith » Mon May 31, 2021 12:20 pm
Thanks Jademan, in the meantime I'll work around it.
