Audacity locks up when trying to save
Re: Audacity locks up when trying to save
Has worked fine since my last post, then windows update and it's locking up again.
Are you using Japanese or similar language at all?
@ Steve, yes I use Japanese since I live in Japan. However, after installing the latest version then uninstalling that because it locked up, installing 2.3 with the same problem and then re-installing 2.4.2 it's back to working normal now. This was an update problem.
There's some information about the issue here: https://support.microsoft.com/en-us/top ... a68e328692
