I found this error to be persisting and I am still using Audacity 2.3.3. Is there anyway to sort out the problem out?
AudioFreak900
Operating System: Windows 7
Post by AudioFreak900 » Thu Mar 25, 2021 10:30 am
This problem has been on going and affected EVERY file, whiles another program overwritten the AUP files.
Is there anyone able to find out why Audacity cannot find or fails to see the file, as a compatible file?
The Audacity version is 2.3.3 and something went wrong, as I do not know why this keeps happening.
Here is the report that I have saved, which looks like it failed to load the FFmpeg, as it seem to also have Errors:
Code: Select all
02:26:22: Audacity 2.3.3
02:26:22: Error: Couldn't find symbol 'AudacityModule' in a dynamic library (error 127: The specified procedure could not be found.)
02:26:33: Trying to load FFmpeg libraries...
02:26:33: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
02:26:33: Looking up PATH environment variable...
02:26:33: PATH = 'C:\Program Files\AdoptOpenJDK\jdk-15.0.2.7-hotspot\bin;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Broadcom\Broadcom 802.11\Driver;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\dotnet\;'
02:26:33: Checking that '' is in PATH...
02:26:33: FFmpeg directory is in PATH.
02:26:33: Checking for monolithic avformat from 'avformat-55.dll'.
02:26:33: Error: Failed to load shared library 'avformat-55.dll' (error 126: The specified module could not be found.)
02:26:33: Loading avutil from ''.
02:26:33: Error: Failed to load shared library '.dll' (error 126: The specified module could not be found.)
02:26:33: Loading avcodec from ''.
02:26:33: Loading avformat from 'avformat-55.dll'.
02:26:33: Error: Failed to load FFmpeg libraries.
02:26:33: Error: Failed to find compatible FFmpeg libraries.
Reason: code tags added
Re: I found this error to be persisting and I am still using Audacity 2.3.3. Is there anyway to sort out the problem out
Post by steve » Thu Mar 25, 2021 11:12 am
FFmpeg is an optional component that enables Audacity to import / export additional file types. It is unrelated to opening projects.
I don't understand what you mean.
I assume that you are getting an error when you attempt to open a saved project.
Is that correct?
What is the error? (If the message is in another language it would be a big help if you could translate it into English for us)
Please attach the ".aup" file to your reply - that may help us to work out what the problem is.
(See here for how to attach a file to a forum post: viewtopic.php?f=49&t=64936)
AudioFreak900
Post by AudioFreak900 » Thu Mar 25, 2021 11:16 am
Oh, the file replacement is meant to be the NCH Audio Converter, which somehow replace the Audacity files oddly.
I have no idea why this happens.
AudioFreak900
Post by AudioFreak900 » Thu Mar 25, 2021 11:22 am
I tried to opening it and it did not work one bit.
Keeps crashing Audacity, when opening it.
Riding Cymbal.aup
(1.5 KiB) Downloaded 3 times
e08087e4.au
(777.08 KiB) Downloaded 4 times
e0808f3f.au
(777.08 KiB) Downloaded 3 times
Post by steve » Thu Mar 25, 2021 11:34 am
Please describe, step by step, what you are doing, what is happening, and what the problem is.
Audacity project files (".aup" files) are not normal audio files and are not compatible with other programs.
To get a normal audio file you must "Export" from Audacity. For example:
"File menu > Export > Export as WAV"
or
"File menu > Export > Export as MP3".
Post by steve » Thu Mar 25, 2021 11:50 am
For Audacity versions older than Audacity 3.0.0 it is essential that you don't modify the "_data" folder in any way.
I have reconstructed the project manually, and it works for me.
Here is a ZIP archive file containing the repaired project. You must "Extract" the contents of this file. That will produce a file called "Riding Cymbal.aup" and a folder called "Riding Cymbal_data".
Launch Audacity, then "File menu > Open" and select the file "Riding Cymbal.aup".
It should open like this:
First Track000.png (12.61 KiB) Viewed 116 times
Here is the ZIP archive:
Archive-project.zip
(1.41 MiB) Downloaded 3 times
AudioFreak900
Post by AudioFreak900 » Thu Mar 25, 2021 11:51 am
When I intended to open one of my Audacity file, I notice that NCH thumbnail is on a 'aup' file and I decided to check it out. It happens to be that NCH Audio Editor is the only audio editor to open it, which I do not know how and why it decided to. So, I deleted it. Then I decided to tested the files on Audacity 2.3.3. and see if that works. This made Audacity crash instead. I tested to do the import method, which works, with a result of one loud 3dB tick to silence. That method failed as well. Afterwards, I decided to check the file properties, which seems oddly fine and unchanged. So, I went to see why this is happening and what to do, whenever I decided to open the file. All I could find is fixing Errors and dealing with corrupt files, which is not the case that I intend to look for. I think the files still work, yet there is something broken and missing.
AudioFreak900
Post by AudioFreak900 » Thu Mar 25, 2021 12:01 pm
Additional notes:
I have not modified the files nor did anything for the past 9+ month, yet the problem appeared without any notice nor anything to say why. Yet, I am happy about the results of how you got to reopening the files.
jademan
Forum Crew
Post by jademan » Sat Mar 27, 2021 11:14 am
So I am thinking that perhaps you installed another program on your machine that for some reason changed the Windows default settings for .aup files. If you think this is the case, then you can google "how to change file associations in windows 7".
I hope this helps. :D
