FFMpeg ??
nathcc
FFMpeg ??
Post by nathcc » Tue Mar 23, 2021 8:38 pm
Can only upload MP3 audio, to upload others, I have to do the ffmpeg thing and I don't know anyone who works at NASA who'll help me with the instructions on how to do it :mrgreen: :mrgreen:
When I click libaries, it shows as having the avformat-55.dll ???
Re: FFMpeg ??
Post by steve » Tue Mar 23, 2021 8:53 pm
That sounds like you already have FFmpeg installed.
Let's check that.
1. If Audacity is running, exit Audacity.
2. Launch Audacity.
3. "Help menu >Diagnostics > Show Log".
4. Either save the log and attach it to your reply, or just copy the contents and paste into your reply.
nathcc
Re: FFMpeg ??
Post by nathcc » Tue Mar 23, 2021 9:07 pm
21:03:52: Audacity 3.0.0
21:03:52: Trying to load FFmpeg libraries...
21:03:52: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
21:03:52: Looking up PATH environment variable...
21:03:52: PATH = 'C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Users\nathc\AppData\Local\Microsoft\WindowsApps;'
21:03:52: Temporarily prepending ';' to PATH...
21:03:52: Checking for monolithic avformat from 'avformat-55.dll'.
21:03:52: Error: Failed to load shared library 'avformat-55.dll' (error 126: The specified module could not be found.)
21:03:52: Loading avutil from ''.
21:03:52: Error: Failed to load shared library '.dll' (error 126: The specified module could not be found.)
21:03:52: Loading avcodec from ''.
21:03:52: Loading avformat from 'avformat-55.dll'.
21:03:52: Error: Failed to load FFmpeg libraries.
21:03:52: Returning PATH to previous setting: C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Users\nathc\AppData\Local\Microsoft\WindowsApps;
21:03:52: Error: Failed to find compatible FFmpeg libraries.
Re: FFMpeg ??
Post by steve » Tue Mar 23, 2021 9:16 pm
OK, thanks. You do not have a compatible version of FFmpeg installed.
Let's install it.
(The full instructions are here: https://manual.audacityteam.org/man/ins ... ndows.html but I'll go through the salient points one post at a time.)
First is to download the correct file.
  1. Go to this page: https://lame.buanzo.org/#lamewindl
  2. Look for the text link: ffmpeg-win-2.2.2.exe
  3. Click with the Left mouse button on that text link to start the download.
  4. When the download is complete, ensure that the name of the downloaded file is: ffmpeg-win-2.2.2.exe
Write back when you have that file.
nathcc
Re: FFMpeg ??
Post by nathcc » Tue Mar 23, 2021 9:22 pm
All sorted and done, I can now upload the intented audio. Thanks for your help.
Re: FFMpeg ??
Post by steve » Tue Mar 23, 2021 9:31 pm
Super.
Out of interest, could you tell us what the initial problem was?
nathcc
Re: FFMpeg ??
Post by nathcc » Tue Mar 23, 2021 9:37 pm
I think like you said it must have been an incompatible version of FFmpeg installed. I could load mp3 audio so your guess is as good as mine.
Re: FFMpeg ??
Post by steve » Tue Mar 23, 2021 9:48 pm
If you're a long time user of Audacity, you may well have had an older version of FFmpeg that is not compatible with current versions of Audacity.
