Hi,
I just downloaded the software and plugged my Mackie board into my laptop. I must be doing something wrong because I am getting no reading on my bass as I try to record. Have I missed a step in the beginning
Thank so much!
A newbie Question
theorcolus
Re: A newbie Question
You should connect all of the equipment before launching Audacity.
Then select the appropriate recording input in the Device Toolbar.
