Hello,
I am having an issue when I export my files. I record in 48,000 Hz, and 24 bit. Save it as AIfF, and then I export it. For some reason after the files have been saved, when I go to open it it is now 32 bit. I have check my preferences, gone through the process several times. And have reinstalled the applications. Any suggestion as to why this might be happening?
Export error
Re: Export error
How are you checking the bit depth? You can check with MediaInfoOnline.
The file size can also tell you (for uncompressed files). There are 8-bits in a byte so (Bit-depth/8) X sample rate (Hz) X number of channels X playing (seconds) gives you the file size.
By default, Audacity converts everything to 32-bit floating-point. It makes "processing" easier.when I go to open it it is now 32 bit. I have check my preferences
Re: Export error
Hmmm, is there any way to adjust default change in the settings?
Re: Export error
Yes there is, but you shouldn't do that.
Audacity works internally in 32-bit float format and for multiple reasons it is best for all of your tracks to be 32-bit float format.
Conversion to a lesser bit format should be done on export. For example, if you export as "24-bit WAV", then Audacity will automatically convert the data and write 24-bit data into the WAV file.
