Won't play a WAV file for opening music
AndySigler
Post by AndySigler » Tue Mar 23, 2021 4:15 pm
I've tried converting an M4A file into a WAV file a couple of different ways and I can then drag-and-drop the WAV file into Audacity but when I try to play it, a pop-up window says "Error opening sound device. Try changing the audio host, playback device and the project sample rate." Brand new to Audacity, I appreciate any help. Thanks.
Re: Won't play a WAV file for opening music
Post by kozikowski » Tue Mar 23, 2021 5:53 pm
That just means it tried to play to your speakers or headphones and couldn't find them.
Are you playing to your computer built-in soundcard or speakers?
Did your wireless headphones go off-line briefly? Those can cause a lot of trouble.
jademan
Forum Crew
Post by jademan » Wed Mar 24, 2021 7:02 pm
Try doing Transport > Rescan Audio Devices, then set your output device (speakers, headphones, etc.) in your Device Toolbar
