Thanks again, Steve. I've spent most of the day "playing" with this - I added tracks to that file, manually: I took the times from a screenshot of the display from Audition (the end time became the same as the starting time for the next track). Then I exported those labels, and looked at the resulting file in a text editor. I couldn't for the life of me figure out what the numbers meant - it never occurred to me that they'd be the time converted into SECONDS!
It seems that I have to re-upload the exported labels file if I save the file as .wav - right? That's a pain in the neck! But actually, once I've saved the tracks, there isn't much need to see them in the full file (though I have gotten used to being able to browse through the whole file and find just the part I need....)
I'm busy working out the work-around now - I may just have to make sure I've got updated track info for the approximately 300 files I've divided in Audition - and add Labels later if/when they're needed.
Thank you for taking so much time to help me.
Export Adobe Audition markers
