Really works audacity with windows 10
audacityisdead?
Post by audacityisdead? » Sun Mar 21, 2021 12:31 am
Hello I have been trying for several days to make audacity works with windows 10, without success...
DVDdoug
Forum Crew
Re: Really works audacity with windows 10
Post by DVDdoug » Sun Mar 21, 2021 12:47 am
Yes, lots of people (including me) are running Audacity on Windows 10.
What version of Audacity? Exactly what's happening? Did you download the official install file from fosshub.com?
audacityisdead?
Post by audacityisdead? » Mon Mar 22, 2021 8:05 am
I have another laptop with windows 10 and i run Audacity version 2.xxx witout a problem. I have downloaded de version 3.0 from the proper site. But in my desktop, it is not working, I am wondering that the Droid cam software I have is blocking the sound port.
Post by steve » Mon Mar 22, 2021 9:54 am
That sounds possible.
jademan
Forum Crew
Post by jademan » Mon Mar 22, 2021 1:45 pm
I see that you have confirmed via this post: viewtopic.php?p=420414#p420414
that you have corrected the problem and that it was, in fact, likely related to the Droid cam.
