Thanks for the report. I forwarded you note along to the developers.
Audacity 3.0.0 Win 10.0.19041 "Failed to open the project's database"
Re: Audacity 3.0.0 Win 10.0.19041 "Failed to open the project's database"
Running macros and I constantly get the "Failed to open the project's database" error. I'm running a batch of about 100 files, but it doesn't happen at the same spot. Sometimes it crashes at file #2 and sometimes file #35, etc. Random. Basically my macros are useless because I can't batch run anything.
So there seems to be a bug in 3.0.0 that causes this problem. It should be corrected in 3.0.2. As I told Magimix98,McCoyCORE wrote: ↑Mon Apr 12, 2021 12:23 amRunning macros and I constantly get the "Failed to open the project's database" error. I'm running a batch of about 100 files, but it doesn't happen at the same spot. Sometimes it crashes at file #2 and sometimes file #35, etc. Random. Basically my macros are useless because I can't batch run anything.
