Split Audio into separate files based on timestamps
jademan
Forum Crew
Re: Split Audio into separate files based on timestamps
Post by jademan » Mon Mar 22, 2021 11:46 am
When you copy/paste data into a spreadsheet, LibreOffice normally asks you to specify separators, in this case, a space or a "-". You may have to manually edit your data and put in commas or change delimiters. You may even have to retype the whole thing. For additional help with LibreOffice, click on "Help" in their main menu. There is LibreOffice Help and Get Help Online, which is likely similar to this forum.
Usually when I have a question about libreoffice, I just go to google and type in, for example, "libreoffice export to text" if I want to know how to export a spreadsheet to a text file.
I hope this helps. :D
