If you want the result to be musical, the modifications should be synchronised to the beat of the music,TinkyWinky wrote: ↑Wed Mar 17, 2021 1:49 pmWhat we're trying to do is not exactly the same though as we don't want to insert speech anywhere; we simply want to scramble the melody of the music so that it doesn't sound predictable (we basically want it to sound like unpredictable 'noise')...
350ms was chosen as a maximum because it approximately matches the length of the shortest words, (it/we/my).
If your project has nothing to do with words you can ignore the 350ms limit.
Do you need the scrambling to preserve the pitch ?, if not ...
