Noise
Elfis
Re: Noise
Post by Elfis » Mon Mar 08, 2021 4:55 pm
In the properties 'box' that pops up for the microphone it only has 1 tab.."General"....and under its properties it has 4 tabs "General", "Driver", "Details", and "Events".....
All that being said...I'm noticing that the rumble/booming has abated.....Not sure what, if anything, I did made a difference though....
Thanks again for you help....
