How to remove mic distortion?
mayahalom
Post by mayahalom » Tue Feb 16, 2021 9:05 am
Hello,
I have the latest version
In the recording i made the mic on the other person neck made some sounds, high and very jarring.
I tried to remove it with "Noise reduction" but unless it is in between people talking and i can remove all of it, i hear it.
I think it is the high dark blue lines.
Is there a way to remove only that sound?
I'm New to Audacity
jademan
Forum Crew
Re: How to remove mic distortion?
Post by jademan » Wed Feb 17, 2021 12:34 pm
Perhaps you would like to post 10 seconds of your .WAV file? See here: viewtopic.php?t=72887
