Importing MP3 from Thumb Drive
chatgroslegrande
Post by chatgroslegrande » Mon Feb 15, 2021 1:58 am
Windows 10, Ver 2.4.2
I have several mp3 on a thumb drive that I want to import to Audacity. Could not find info in Manual. Thank you.
Re: Importing MP3 from Thumb Drive
Post by steve » Mon Feb 15, 2021 10:49 am
What info do you need?
I would recommend copying them to the computer's hard drive first, then import them into Audacity from the hard drive.
waxcylinder
Post by waxcylinder » Mon Feb 15, 2021 11:46 am
For QA testing I frequently use File>Import to import audio files from thumb drives - works a treat.
Peter.
