Hello!
I have this audio file i would like to use for my custom weapon pack i am creating for DayZ but in the audio file there is a ping sound of the shell ejecting mixed in with the shooting sound fade-out, i am by no means mediocre at audio editing or messing around with audio softwares so bare with me!
I am just wondering if there is any way i can filter it out somehow without distorting the main audio too much? or perhaps even completely remove it!
Here is the audio file if you would like to take a quick look and see if its actually possible or not!
https://drive.google.com/file/d/1ENk-yk ... sp=sharing
I would like to know if i can remove this pinging noise!
Re: I would like to know if i can remove this pinging noise!
Trebor wrote: ↑Sat Feb 13, 2021 11:19 amI think that's removable with Audacity's spectral editing tools.
- Attachments
- ''SCARH-3'' before-after ping-removal with Audcaity.wav
- Warning: this is LOUD, (peak 0 dBFS).
- (1.14 MiB) Downloaded 8 times
omg that is amazing, was it hard to do? also thank you very much!
Any chance you could explain what you did or somehow show me what you did? i tried following the video you linked but i cannot wrap my head around how to figure out what part the ping sound is, like i said i by no means even mediocre at this and only just downloaded the program!Trebor wrote: ↑Sat Feb 13, 2021 12:56 pmTrebor wrote: ↑Sat Feb 13, 2021 11:19 amI think that's removable with Audacity's spectral editing tools.
