Re: How can I remove all frequencies above a certain pitch with Audactiy?
Post by steve » Thu Feb 11, 2021 10:34 am
Hamm542 wrote:
Thu Feb 11, 2021 4:41 am
How do I use Audacity to filter out all frequencies above a specific pitch?
Use the "Low Pass Filter" (see: https://manual.audacityteam.org/man/low ... ilter.html)
However, that will probably make the recording sound dull.
Piezo pickups often over-emphasize frequencies around 2000 Hz (2 kHz). If you use "Plot Spectrum" (https://manual.audacityteam.org/man/plot_spectrum.html) you will probably see a pronounced bump, spike or bunch of spikes around 2 kHz (may be at a higher frequency depending on the pickup).
Make a note of where that peak occurs, then try the Filter Curve EQ effect to reduce those frequencies. (See: https://manual.audacityteam.org/man/fil ... ve_eq.html).
[Unfortunately Hamm542 was a spammer and has been permanently banned. Leaving this reply as it may be useful for future users.]
