No file or Directory found when trying to install
Re: No file or Directory found when trying to install
Post by steve » Tue Feb 09, 2021 11:34 am
Your profile says that you use Windows 10, and this is the WIndows forum, so I assume that you are using Windows.
The "Flathub" packages are for Linux and will not work on Windows.
Audacity for Windows is available via the Audacity website: https://www.audacityteam.org/download/windows/
You need the "Windows Installer" version.
