I am trying to import a MP3 recording to edit it and I get the following message: bad scalefactor selection info
is there a fix or a workaround?
TNX
error message: bad scalefactor selection info
sorry forgot Windows 10, Audacity 2.4.2
Re: error message: bad scalefactor selection info
Try this work-around which is generally more tolerant.
