Hi
I have an audio file that I went through and at points where I wanted to keep I added a label saying "keep"
I did this by going to edit - Labels - Add Label to Selection.
Now that I done that I want to delete all the recordings in between each of my labels but when I select the recording part I don't want and hit delete it shifts my labels down making all future labels out of sync with what I want to keep.
Is it possible to keep them grouped with what I selected?
How To Trim File But Keep Labels Current Position?
waxcylinder
Re: How To Trim File But Keep Labels Current Position?
