Hi,
As the title indicates, I have defined several region labels on my track. I want to export each region into a separate file but when I go to file/export multiple I can only export by tracks -- the labels radio button is greyed out. See attached screen shot.
Appreciate any help.
Best,
ileana
Export Multiple by Label greyed out in Audacity 2.4.2 on Windows 10 Pro
- Attachments
- Screen Shot.pdf
- (237.35 KiB) Downloaded 11 times
waxcylinder
Re: Export Multiple by Label greyed out in Audacity 2.4.2 on Windows 10 Pro
It's because you have two label tracks - and the top one is empty.
Export Multiple always uses the topmost label track for export by labels.
Peter.
Peter.
Yup, I just noticed that I had two tracks
. Thanks so much, Peter for the prompt response!
Best,
ileana
Best,
ileana
