sound issue
judithkb
sound issue
Post by judithkb » Thu Feb 04, 2021 5:18 pm
I have linked Audacity to my Scarlett 2i2 3rd gen interface and microphone and selected the correct options for the input and output but when I record there is no sound-just a flat line
I have windows 10 and audacity 2.4.2 downloaded
any help would be appreciated ( in very simple language please!)
DVDdoug
Forum Crew
Re: sound issue
Post by DVDdoug » Thu Feb 04, 2021 6:50 pm
Are the LED indicators on the Scarlett showing a signal? If you shout into the mic with the gain turned-up do the indicators turn red?
If you plug headphones into the interface and select direct-monitor are you hearing anything?
You selected the Scarlett (or something that says "USB") as your
Audacity Recording Device
judithkb
Re: sound issue
Post by judithkb » Thu Feb 04, 2021 7:24 pm
Yes the LED lights are showing and if I shout with the gain turned up the gain indicator turns red
headphones dont seem to make much difference - I can hear with or without them (they came with the Scarlett package)
judithkb
Re: sound issue
Post by judithkb » Thu Feb 04, 2021 7:26 pm
yes I selected Scarlett as my recording device
judithkb
Re: sound issue
Post by judithkb » Thu Feb 04, 2021 7:55 pm
not sure what I did but I seem to have resolved the issue
thanks
