Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
jademan
- Forum Crew
Post
by jademan » Wed Feb 03, 2021 8:35 pm
jvd0213 wrote: ↑Mon Feb 01, 2021 10:29 pm
I've used Cntrl + I and the Edit > Clip Boundaries option to split my audio track and neither is working to split the track. What could I be doing wrong?
Thanks
It is important to first click in the track at the location where you want the split. I say this because I thought I had done that, but the menu item was grayed out. I said to myself, "self, what is going on here?" So I swiped a few seconds of audio and the menu item magically appeared, then I created two split points. Then I clicked in a single place on the track then, Edit > Clip Boundaries > Split, and then I worked again. For some reason, I suppose have a habit of clicking in the gray area outside the track before going to the menu. That breaks it!
Ctrl-I, however works just fine as I don't click outside of the track for that one. And the key was already enabled for me.
I hope this helps.
steve wrote: ↑Wed Feb 03, 2021 12:36 pm
To use the "Split" function to create a single split, you must click (once) on a track and then "Ctrl + i" (or "Edit > Clip Boundaries > Split")
just as steve says!
jvd0213
Post
by jvd0213 » Wed Feb 03, 2021 10:58 pm
So, I went in a created a new "testing" track. The "Ctrl +i" option worked perfectly to Split the track.
I went back into the current project I'm working on and tried that same "Ctrl +i" option, but the track did not Split. The "Ctrl + i" option was enabled. I did already normalize, used noise reduction and compressed the track prior to trying to split it. I realized after I did those things that I needed to go and add something back into the audio. Could that be the reason why I can't split the track now?
Thanks
jvd0213
Post
by jvd0213 » Wed Feb 03, 2021 11:07 pm
Nevermind... I figured out the problem and it's now fixed.
Thank you guys for all your help and patience!!
jademan
- Forum Crew
Post
by jademan » Thu Feb 04, 2021 1:11 am
jvd0213 wrote: ↑Wed Feb 03, 2021 11:07 pm
Now you have us at a disadvantage.
Yes, you are welcome.
- Site Admin
Post
by steve » Thu Feb 04, 2021 2:58 am
It would help us to help others if we knew what fixed it. I'm guessing that I overlooked something that I assumed was obvious but wasn't.
