WAVES - Installed on AUDACITY.
pennyroyaltea94
Post by pennyroyaltea94 » Mon Feb 01, 2021 3:09 pm
Hi Guys , as you know , their is no instructions given for this as I guess WAVES does not expect you to still be using a free DAW when your buying Premium Plugs Ins. The only way this works for me is this , You COPY AND PASTE this WAVES Folder and paste inside the AUDA Plugins Folder.
You will have to hit OKAY on a lot of FAILED Connections during the ENABLE SCAN, but eventfully AUDA catches the FILES it needs and your WAVES Plug Ins will be running in no time.
wave installment.jpg (171.44 KiB) Viewed 444 times
