Learning curve
Learning curve
I am trying to convert cassettes to mp3 files and I cannot seem to figure out how to split the tracks that are on one of the sides of a cassette. I've noodled around some in the program but never seem to figure it out. I have a hunch that once I either find the proper tutorial or get the right advice I will hit the ground running and be just fine. Thanks in advance for any direction you can provide!
waxcylinder
Re: Learning curve
Please see: https://manual.audacityteam.org/man/spl ... racks.html
It's part of this Tutorial set: https://manual.audacityteam.org/man/tut ... to_cd.html
