Behringer umc22 [SOLVED]
Lindsayj
Post by Lindsayj » Tue Jan 26, 2021 3:21 pm
Hi... trying to use Umc22 with Audacity......
Audacity picks up the Behringer in/out drivers ok.... I’m able to record a basic guitar track.... but if I try to record another track either over an imported backing track...or the first track I’ve recorded, I get error 9999(also can’t now hear the first track).... I’ve tried everything I can think of ...help!!
Many thanks..
Lindsayj
Re: Behringer umc22
Post by Lindsayj » Tue Jan 26, 2021 6:34 pm
Looks as if this isn't a Behringer issue.....the same issue seems to be pretty common in the Forum but haven't seen any fixes..
Re: Behringer umc22
Post by steve » Tue Jan 26, 2021 7:13 pm
I get error 9999
What is the full and exact message?
(some info here: https://manual.audacityteam.org/man/faq ... vice.22.3F)
Lindsayj
Re: Behringer umc22,,fixed
Post by Lindsayj » Tue Jan 26, 2021 8:06 pm
Ok......cracked it.......set everything to 44100...can hear original track and record in new track,,,,,,,many tks.
nawfel09
Re: Behringer umc22
Post by nawfel09 » Fri Jan 29, 2021 9:05 am
try to watch this https://youtu.be/ApwXGPVQTcE . i so helpful
Re: Behringer umc22 [SOLVED]
Post by steve » Fri Jan 29, 2021 10:27 am
Thanks for trying to help nawfel09, but the problem was already solved:
