Filter Curve is gone
Omar Taleb
Post by Omar Taleb » Mon Jan 25, 2021 4:58 pm
Hello there!
I have downloaded multiple versions of audacity on my laptop, but I can not fins ''filter curve'' in the effect menu. What shall I do?
Re: Filter Curve is gone
Post by steve » Mon Jan 25, 2021 5:00 pm
Do you have more than one version of Audacity installed?
Omar Taleb
Post by Omar Taleb » Mon Jan 25, 2021 5:22 pm
I uninstalled and reinstalled audacity, sometimes newer versions and sometimes older versions.
It turned out that the plug-ins won't stay enabled, do you know how I can solve that? My audacity current version is 2-2-1.
I added the plug-in ''filter curve'' many times, but it stays disabled. My laptop has window 10 64 bit.
Post by steve » Mon Jan 25, 2021 5:28 pm
Uninstall all versions of Audacity from your computer.
Open the hidden folder:
Code: Select all
Users\\<username>\\AppData\\Roaming\\audacity\\
and delete these three files:
  • audacity.cfg
  • pluginregistry.cfg
  • pluginsettings.cfg
Download the "Audacity 2.4.2 installer" via the Audacity website: https://www.audacityteam.org/download/windows/
(on the FossHub download page, it's the text link: "Audacity Windows Installer")
Run the installer to install Audacity 2.4.2.
