Audacity not recognising soundcards
Malkie
Re: Audacity not recognising soundcards
Post by Malkie » Wed Jan 27, 2021 12:55 pm
Many Thanks
Malkie
jademan
Forum Crew
Post by jademan » Thu Jan 28, 2021 10:04 pm
Malkie wrote:
Mon Jan 25, 2021 4:46 pm
Hi, my platform is windows 10 version 20H2
I have a Realtek audio card and also a Steinberg UR824 installed.
Malkie
I believe you are going to find that the Steinberg software * requires * ASIO to use more than two channels and the current "public" release of Audacity does * not * support ASIO. So you have two options:
1) Use different software that does support ASIO. For example, Reaper , Cakewalk , Studio One, Ableton Live, Cubase, etc.
2) Build your own "private" version of Audacity that * does * support ASIO: See here:viewtopic.php? t = 112082 & start = 10 # p410225
I hope this helps. : :D
