Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
jademan
- Forum Crew
Post
by jademan » Mon Jan 25, 2021 8:58 pm
izumi wrote: ↑Mon Jan 25, 2021 8:24 pm
I cant activate the effect... literally i go to "Limiter" i press enable it wont enable...
So make sure you click "OK", after enabling it. Then enable doesn't take until you click OK.
I hope this helps.
izumi2
Post
by izumi2 » Mon Jan 25, 2021 9:50 pm
Yes! I cant use enable the effect at all. I have the 2.4.2 version....
- Site Admin
Post
by steve » Mon Jan 25, 2021 9:54 pm
izumi2 wrote: ↑Mon Jan 25, 2021 9:50 pm
Please describe "click by click" exactly what you are doing and what you see. Post screenshots if necessary. Remember that we can't see your computer so we are relying on you to be our eyes.
If you've not already done so, read through this part of the manual:
https://manual.audacityteam.org/man/man ... yzers.html
izumi2
Post
by izumi2 » Mon Jan 25, 2021 9:58 pm
I click on effect tab in audacity, choose limiter, press enable and OK, it doesnt show up... comon guys XD
- Site Admin
Post
by steve » Mon Jan 25, 2021 10:04 pm
izumi2 wrote: ↑Mon Jan 25, 2021 9:58 pm
Before you click the Enable button:
1. Does it say that "Limiter" is enabled, disabled or new?
2. What does it say the "path" is to "Limiter"?
press enable
3. After to click the "Enable" button, does it say that the Limiter is enabled?
4. Is "Low-Pass Filter" enabled?
izumi2
Post
by izumi2 » Tue Jan 26, 2021 12:18 am
It doesnt say anything. It jsut doesnt enable... when i go back to effect and look at limiter it still says disabled.... yes low pass filter is enabled... i do ahve other things enabled... just "LIMITER" doesnt want to enable idk
- Site Admin
Post
by steve » Tue Jan 26, 2021 12:43 am
Please post a screenshot so that we can see what it looks like in the plug-in manager.
