no sound
benjaminAS
no sound
Post by benjaminAS » Sat Jan 23, 2021 4:53 pm
i have a yamaha AG 06 mixer, and try to get signal in to audacity? (via usb) no respons? i have try the 3 difrent indput wasapi mme and windows direct? can you help me? i have connection to the PC in yamahas application?
DVDdoug
Forum Crew
Re: no sound
Post by DVDdoug » Sat Jan 23, 2021 5:31 pm
This might be obvious but did you select the USB mixer as your Recording Device?
Are you the LEDs on the mixer showing a signal? Are you getting anything out of the analog or headphone outputs?
jademan
Forum Crew
Re: no sound
Post by jademan » Mon Jan 25, 2021 1:58 am
Also, make sure you plug in the mixer *before* starting Audacity. Else Transport>Rescan Audio Devices.
And check here for microphone permissions: https://support.microsoft.com/en-us/win ... 8ca45f577a
When you say no response, what does that mean?
