MP3 import stopped working!!!
Re: MP3 import stopped working!!!
Post by steve » Thu Jan 21, 2021 8:01 pm
Siggy62 wrote:
Thu Jan 21, 2021 7:58 pm
13:57:23: Error: Failed to find compatible FFmpeg libraries.
You don't have a compatible version of FFmpeg installed.
If you installed FFmpeg for an older version of Audacity, it may be too old for the current version of Audacity, in which case you can uninstall it (recommended before installing a newer version).
See here for how to install FFmpeg for Audacity: https://manual.audacityteam.org/man/ins ... html#winff
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 8:31 pm
Thanks, upon further examination, it seems I had the library pointed to the wrong file.
Now it shows FFmpeg Library Version F(55.33.100),U(52.66.100). Does that look right? It is working now for both MP4 and MP3 file imports. :D
Post by steve » Thu Jan 21, 2021 9:59 pm
That looks better :D
