importing mp3 files
tomholder
importing mp3 files
Post by tomholder » Sun Jan 17, 2021 7:44 pm
I recently purchased an mp3 file on Amazon.com hoping to import it into audacity and play it. The import was successful but I get no sound when I play it. Any ideas?
DVDdoug
Forum Crew
Re: importing mp3 files
Post by DVDdoug » Sun Jan 17, 2021 8:54 pm
How do you know it was successful? Do you see the waveform? Have you tried other files?
Make sure you've selected the correct Playback Device.
I assume you also wanted to edit it?
...As you may know, MP3 is lossy compression. When you open in Audacity it gets decompressed. If you then re-export as MP3 it goes through another generation of lossy compression and the "damage" accumulates. So, try to minimize the number of times it's compressed.
There are some special-purpose MP3 editors, such as MP3directCut that can do some limited editing without decompressing the MP3.
jademan
Forum Crew
Post by jademan » Mon Jan 18, 2021 4:10 pm
What happens when you start with an empty Audacity project, Generate DTMF Tones, then try to play it?
