Im needing some help
dustypop123
Post by dustypop123 » Fri Jan 15, 2021 4:45 pm
hello im a new content creator and im trying to clean up my audio but i cant get this static sound the be removed, i have looked through the filters but i cant seem to find the right one. any help would be apricated
Sample.mp3
(206.12 KiB) Downloaded 9 times
Re: Im needing some help
Post by kozikowski » Fri Jan 15, 2021 4:52 pm
That's really damaged. How are you recording that? Microphone? Interface? I don't think you're going to get to good audio with effects and filters. Your recording system is broken.
dustypop123
Post by dustypop123 » Fri Jan 15, 2021 5:40 pm
im using a blue snowball i never had this issue before, ill take a look at my cords to see if something is messed up.
Trebor
Post by Trebor » Fri Jan 15, 2021 7:37 pm
... im a new content creator and im trying to clean up my audio ...
Attachments Sample.mp3 (206.12 KiB)
Sounds like Windows-audio-enhancement processing, which should be turned off ...
https://youtu.be/sxnUjiGgBaI
(in both the recording & playback tabs)
dustypop123
Post by dustypop123 » Fri Jan 15, 2021 10:47 pm
Thank you I will try this.
Post by kozikowski » Fri Jan 15, 2021 11:01 pm
I used a Snowball for a while and it didn't sound anything like that.
