Error Importing on 2.4.2 version
Billymj63
Re: Error Importing on 2.4.2 version
Post by Billymj63 » Thu Jan 14, 2021 3:22 pm
Thanks a lot for answering my questions. Appreciate it!
NicaKent
Post by NicaKent » Sun Jan 24, 2021 8:29 pm
steve wrote:
Thu Jan 14, 2021 10:20 am
It doesn't matter so much now because the bug has been fixed, but normally you would use "Save" unless you wish to save the project with a different name or different location.
This bug has not been fixed. I updated Audacity to 2.4.2 yesterday since I was back to doing some work using it. I created a new project and used Save As to save it. I have a couple of programs that use a default name and location if I don't do that.
Yesterday, spent hours editing a project. Then closed it and went to bed. This morning, I recorded some quick audio projects before returning to work on yesterday's project.
All three projects will not open, and give the very same error as OP.
Looking at the file, it appears to be well-formed XML, with no obvious syntax errors.
OS: Windows 10
Audacity Version: 2.4.2
Post by steve » Sun Jan 24, 2021 11:58 pm
The bug I was referring to was 100% repeatable. Are you able to reproduce the problem? If so, please give precise steps to allow us to reproduce the issue.
jademan
Forum Crew
Post by jademan » Tue Jan 26, 2021 3:13 pm
What steve said. Also note that in the 2.2.1 bug the .aup file did *not* contain well-formed XML.
