Making volume conIsistent
Watt
Post by Watt » Sat Jan 09, 2021 4:11 am
Question from a newbie: I am recording organ music (small home electric organ). The volume from the organ is consistent throughout the piece of music. However, when I record the piece, on playback the volume starts out relatively loud, then seems to adjust itself downward as the piece progresses. If there is a rest (brief moment of silence in the music), the volume pattern repeats itself. When I use Normalize or Loudness Normalization, it adjusts the volume proportionally over the whole piece. Is it possible to make the recorded volume more or less even? Thanks.
Re: Making volume conIsistent
Post by steve » Sat Jan 09, 2021 11:40 am
That can be caused by Windows Sound "Enhancements". See here for how to turn off all of the "enhancements": https://manual.audacityteam.org/man/faq ... hancements
Watt
Post by Watt » Sat Jan 09, 2021 11:31 pm
Excellent. This simple solution did the trick.
