Problem when I press record
Mateo
Operating System: Windows 7
Post by Mateo » Thu Jan 07, 2021 12:17 pm
Dear Friends. I have downloaded the 2.4.2 versión and I have Windows 7.
When I press thr Record button, the following message appears: Error opening the recording device. Error code 0 Success.
Can you tell me the solution?
jademan
Forum Crew
Re: Problem when I press record
Post by jademan » Fri Jan 08, 2021 12:58 pm
See here: viewtopic.php?p=405613
and here: viewtopic.php?p=383219
I hope this helps. :D
