Hi everyone
OS - Windows 10. I'm using Audacity 2.4.2 and I hear distortion (pops and clicks) when I playback any of my files. I tried to check files in several programs (work time,iTtunes) - everything works fine. I'm stumped because I uninstalled the program and reinstalled but still getting the pops.
Can anyone help?
Thanks
different weird sounds while using Audacity
Re: different weird sounds while using Audacity
Reinstalling Audacity doesn't always reset Audacity. Audacity keeps Preferences and Settings in a separate place to make upgrading easier. There should have been a [X] somewhere that says Reset Audacity or Reset Preferences, or something like that while you're installing. That will make Audacity do a clean start.I uninstalled the program and reinstalled
Are you by any chance using cloud storage for Audacity? Audacity is not a fan of cloud systems and they may create problems.
DeonEva wrote: ↑Wed Jan 06, 2021 5:03 pmHi everyone
OS - Windows 10. I'm using Audacity 2.4.2 and I hear distortion (pops and clicks) when I playback any of my files. I tried to check files in several programs ([Advertising is not permitted],iTtunes) - everything works fine. I'm stumped because I uninstalled the program and reinstalled but still getting the pops.
Can anyone help?
Thanks
i am using rclone. I thought about it and probably will have to abandon any cloud storage...kozikowski wrote: ↑Wed Jan 06, 2021 5:28 pmReinstalling Audacity doesn't always reset Audacity. Audacity keeps Preferences and Settings in a separate place to make upgrading easier. There should have been a [X] somewhere that says Reset Audacity or Reset Preferences, or something like that while you're installing. That will make Audacity do a clean start.I uninstalled the program and reinstalled
