Audacity with Focusrite Scarlett 4i4
Frank39
Post by Frank39 » Wed Jan 06, 2021 7:49 am
Hello,
why Audacity doesen't detect the Input 3 and 4? I put in my Stagepiano.
If i use Line 1 and 2 Audacity detect correctly... But I want to use Line 3 and 4 for my Stagepiano...
Thank you
Frank
Re: Audacity with Focusrite Scarlett 4i4
Post by steve » Wed Jan 06, 2021 1:58 pm
Please post your "Audio Device Info" (See: https://manual.audacityteam.org/man/hel ... stics.html)
jademan
Forum Crew
Post by jademan » Thu Jan 07, 2021 9:18 pm
Also, in your Device Toolbar: https://manual.audacityteam.org/man/device_toolbar.html, try changing your Audio host between MME and Windows WASAPI and Windows DirectSound. See if you can select all four recording channels with one of them selected.
If not, you may have to use ASIO to see all four channels. Audacity does not "ship" with built in with ASIO support, however it must be compiled in. See viewtopic.php?p=410225#p410225.
There are other Windows software packages that do support ASIO. I believe cakewalk, for example, is free and supports ASIO.
I hope this helps. :D
