failed to read from a file in C.
marqueschaney
I watched videos on Youtube and read everything on here but I still cant export my 11-minute audio. Ive had no problem exporting this same project into a .WAV file until yesterday. Could it be that my One Drive just kicked in randomly?
Re: failed to read from a file in C.
If your project is on One Drive, then that is very likely to be the problem.marqueschaney wrote: ↑Sat Jan 02, 2021 7:48 pmCould it be that my One Drive just kicked in randomly?
marqueschaney
so i lost the file forver?
Can you open the project in Audacity?
Does the project play?
marqueschaney
yes the file opens ands plays fine. I even tried saving the project by different names and saving it to my desktop.
Good - does that copy work OK?
marqueschaney
The project that I saved to my desktop is failing to be exported too. Everything plays well but I cant get the audio online for my podcast.
Can you export it to your "Desktop" folder like this:marqueschaney wrote: ↑Mon Jan 04, 2021 4:49 amThe project that I saved to my desktop is failing to be exported too.
1. Launch Audacity (if it was already open, quit and then launch it again)
2. "File menu > Open" and select the version of the project that is on your Desktop.
3. "File menu > Export > Export as WAV" and name the new file "test.wav"
What happens?
marqueschaney
I followed your steps and after 15 seconds of elapsed time I got an error message "failed to read from a file in C still."
How big is the "_data" folder?
