Windows 10, Audacity Version 2.4.2
I've been recording a 90 yo's audiobook for which I've provided a dropbox link for a short sample. It might be my dumbo guitar player ears, but I hear a strange sound on the back end of her voice that I have no idea how to edit out. It expands and contracts with her words and phrases. It's not an echo. It's not a reverb. I built a near soundproofed enclosed hut to use for recording, so it's not room noise. And, if I use the same mic with my own voice, I don't get the same effect. In the guitar world, I'd have to use a flanger effect pedal to get something close. Is there a word for this? Can you hear it too? Can I fix it in Audacity somehow and remove it?
https://www.dropbox.com/s/cl4x7944ffwzl ... t.mp3?dl=0
How to Edit Strange Sound on Voice
LionsAlwaysWinBook
Re: How to Edit Strange Sound on Voice
It is "compression artifacts". It's a side effect of file compression (reduced file size) when using "lossy" compression formats such as MP3.
Unfortunately there is no effective remedy.
You can create it yourself as an experiment:
1. Start with a high quality voice recording in Audacity.
2. Export as a WAV file - this is your "control sample" for comparison purposes.
3. Export as an MP3 and set the following MP3 options (https://manual.audacityteam.org/man/mp3 ... tions.html)
- Bit Rate mode = Constant
- Quality = 16kbps
Observe that the sound quality of the MP3 is rather bad.
