Time Shift tool is not working Audacity 2.4.1
The audacity version 2.4.1 for windows 10.I couldn't move single clip alone , while using time shift two tracks moving at a time. but i want to add last track to end of the first track. Time shift tool not at all working even the status of it selected also
- Attachments
- audacity issue.png (118.06 KiB) Viewed 130 times
Re: Time Shift tool is not working Audacity 2.4.1
The current version of Audacity is 2.4.2. It is available via the Audacity website: https://www.audacityteam.org/download/windows/
Disable it in the "Tracks" menu.
More info: https://manual.audacityteam.org/man/syn ... roups.html
That's because you have "Sync-Lock" enabled. That's also what causes the "clocks" to be shown in the selection.
