Exporting to WAV problem with dropout labels
dlmcpeters
Post by dlmcpeters » Mon Dec 28, 2020 8:31 pm
I am using Audacity 2.4.2 on windows 10. New user recording LPs. I get one or two dropout labels in the track bars. I want to export to tracks using labels. The export treats the dropout label like the labels I create for tracks and creates a wav file starting at the dropout.
How do I prevent this from happening? I have turned off dropout detection as a brute force way, but would prefer to have the dropouts detected in case a given LP has lots of problems.
waxcylinder
Re: Exporting to WAV problem with dropout labels
Post by waxcylinder » Tue Dec 29, 2020 12:16 pm
If you already have a label track before you start then the dropout detector will create a new label track for its dropout labelling. Export Multiple always uses the topmost label track so will ignore the dropout label track - or you can just delete it afyer you have dealy with the dropouts.
If you had m=no label track to start with
1) deal with the dropouts
2) delete the dropout label track
3) create a new label track for labels at your song breaks
4) Export Multiple.
BTW it's not your LPs that cause the dropouts its the PC/soundcard/drivers that will be doing that.
Peter.
dlmcpeters
Post by dlmcpeters » Tue Dec 29, 2020 5:21 pm
Perfect. Thanks.
