Problem with Recording Speed
globetrotter1610
Post by globetrotter1610 » Sun Dec 27, 2020 10:28 pm
I am running Audacity 2.4.2 on Windows 10. I am in the middle of recording an audiobook.
I have somehow inadvertently changed the recording speed (it is now slower) in the middle of a recording. I have double checked every setting I can think of with no luck.
Any suggestions? I am desperate.
Thanks,
Bill
Re: Problem with Recording Speed
Post by steve » Mon Dec 28, 2020 1:02 pm
Try saving the project, then close and relaunch Audacity, then make a test recording in a new project. Is it recording normally?
